Sentra Spec V Limp Mode Issue
ddsvi
Car: 02 Sentra Spec V
08 Nissan Titan
I am having an issue with my 02 Spec V right now. The car keeps going into Limp Mode. It is throwing these 2 codes:
2127 and 2138 Both are related to APP sensor
I have already replaced the Pedal/App Sensor assembly, cleared the codes and within a day the problem has come back. Car is going back into Limp mode very frequently and still throwing the same 2 codes.
Can anyone give me any pointers on what to do next?
06_blkout
Car: 2008 Nissan Sentra SE-R Spec V
2006 Nissan Sentra SE-R Spec V (Sold)
2003 Nissan Sentra GXE
What's the code description?
ddsvi
08 Nissan Titan
P2127 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
06_blkout
Try this, let me know if it works or not and we'll go from here :)
Pedal Relearn Procedure
Accerlerator Pedal Released Postion Learning is and operation to learn the full released postions of the accerlerator pedal by monitoring the accelerator pedal sensor output signal. It must be performed each time harness connector of accelearator pedal postion sensor or ECM is disconnected.
1. Make Sure the acceleartor Pedal is fully released
2. Turn Ignition switch ON and wait at least 2 Seconds.
3. Turn ignition switch OFF and wait at least 10 Seconds
4. Turn Ignition switch ON and wait at least 2 seconds.
5. Turn Ignition switch off and wait at least 10 seconds
ddsvi
08 Nissan Titan
Hey blkout,
Here is what I did yesterday afternoon:
Tested battery voltage while car was off. 12.5Volts
Tested battery voltage while car was on. 14.4Volts
Disconnected the TB harness, verify that the pins and harness were clean. Reconnected harness
Did Pedal Relearn Procedure
Did Throttle Valve Relearn Procedure
Did Idle Air Volume Relearn Procedure
Cleared the codes
This morning the car went back into limp mode and threw code:
What would you suggest I do now?
Thanks for the help
06_blkout
Check the wiring harness from pedal to wherever it goes up behind the dash, make sure nothing is rubbed through and grounding out on some metal.
ddsvi
08 Nissan Titan
I just ran out and checked and couldnt find any rubs or wearing on that cable.
06_blkout
And you got a brand new pedal assembly put on?
ddsvi
08 Nissan Titan
Yes sir.
06_blkout
Well if the wiring/terminals aren't messed up, I'd try bringing back the pedal and exchanging it with another man if they'd let you.
06_blkout
If that's not it man I'd start looking at the throttle body and ECM....this one's got me stumped too :(
ddsvi
08 Nissan Titan
I went ahead and ordered a throttle body today. Will update ya once it comes in. Its only about $100, cheaper than an ECU. So I will eliminate that first.
ddsvi
08 Nissan Titan
I replaced the Throttle Body last night. Did the 3 relearns and so far so good. Drove it for about 4 miles last night to test, then drove an hour to work this morning. Going to wait a week or so and see if I have any more issues.
06_blkout
Good man, glad to hear it :)
Post up if you have any more issues.
ddsvi
08 Nissan Titan
Well crap, After 5 days the SES light has come back on. Its the same code.
now im not sure what to do next.
