SENTRA SE-R SPEC V LSD IN ALTIMA COUPE?
All things Altima Coupe.
BrugmanR
Car: 2008 Nissan Altima 2.5 S
I figure it would work in the 2.5, but does the 3.5 share the same transmission?
BrugmanR
The reason why I ask is I know spec V guys have done VQ35 swaps and it looks like all they did was change the bell housing and use the same transmission. This makes me think that parts would be interchangeable. That's why I asked if you could use the Spec V LSD in the altima coupe.
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
This is interesting. Id like a better LSD.
Would this part help add more whp?
xckid
Car: 2004 Chevy Blazer ZR2
im no fwd guy but im assuming vlsd all work in the same way in fwd rwd and awd
So if thats the case then no a vlsd wont add more whp
it will help you put down more of your hp your already have you'll gain -better launches -slightly better cornering you wont be gaining more hp. though.correct if im wrong though dont hold me to it
Zerep
Car: A/C 2.5R
yeah correct me if im wrong but LSD just makes you seem like your going faster But really all it does is make sure both wheel are spining right now if you step on it i believe one wheel takes over with a lsd the transfer to both is equal.
BrugmanR
I think a Helical LSD would be great for our cars in regards to putting power to the ground and taking turns. I don't think there are any aftermarket companies that offer LSDs for the Altima. From my understanding, VDC kind of works like an electronic LSD, but I don't see it being that great. Thats why I asked if anyone thinks the Spec V Lsd would work with the Coupe.
Hussain
Car: 08 Altima Coupe 3.5se CVT
i think VDC is supposed to be like traction control in the sense that when you start to spin, it cuts the power.... traction control is horrible, i hate it.... i don't know much about the VDC but i don't think it will be any where near as good as a Helical LSD
CoupeSlate
Car: 08 Altima Coupe 3.5SE CVT, Dark Slate Premium Package
you post whore and no i didn't see you wave at me because i was texting you
marlin29311
Car: 2008 Infiniti G35x
Hussain wrote:i think VDC is supposed to be like traction control in the sense that when you start to spin, it cuts the power.... traction control is horrible, i hate it.... i don't know much about the VDC but i don't think it will be any where near as good as a Helical LSD
The VDC system does act like an eLSD - having a mechanical one would be much better - but you use what you got...
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
I would be good for the 6 speed, not for the CVT though. Get larger/wider rims and you will get the same effect on a n/a CVT coupe. I never slipped with with car n/a, and I barely slip with the turbo, this is with 8 inch wide 19's though. I think an LSD on the CVT would start breaking components within the CVT. It doesn't like tons of stress.
