And.... ??RED_DET wrote:it's female driven.
That's a pretty ridiculous statement.. I know of maybe 3 QR's that have blown up, boosted. They are very reliable at 300whp/280wtq or 8-9psi with any of the available turbo systems on the market. The QR's design is lightyears ahead of the SR in terms of block and head layout. The cylinder head flows better than a SR20VE head, and the block is die cast, which is much stronger. Also, the bed-plate (split bock) layout, is WAY stronger and more rigid than the SR's main cap/girdle structure. The early engines did have oil consumption issues because of a very hard piston ring design, and the crazy rod/stroke ratio. However, most of those issues have been fixed, and reliability has gone way up. In built form, NO SR, shy of a built up turbo VVL will touch the QR's powerband.RED_DET wrote:The tried and true always prevail. I own a spec and the motor is garbage. Burns oil like its going out of style and it's female driven. Engine has 43k miles and the transmission was replaced with 10k on it, I guess the motor might be next. By far the worse nissan I have owned and all the other nissans I had were powered by SR's, except the G35. Like I have said time and time again, we nissan quit making the classic se-r, they should have stopped there, because its been on a downward spiral since. 200sx was decent, but the lowport design wasn't well liked. Then the b15 se with its roller rocker motor and now lets completely redesign the drivetrain with the QR, that will blowup with more than 7-8lbs of boost on a t3/t4 setup. Unless the motor is completely rebuilt. Hell it will blowup without boost, oil consumption will be the demise.
that's funny....my wife and i drive a 400+ whp Spec every day with no problems....amazing what proper boost control can do!RED_DET wrote:Why are we really comparing those numbers for, anything above 350whp on a FWD car that only weighs 2500-2700lbs is just plain stupid to try and drive on the street. I can destroy the tires in 1st, 2nd and give me a cool night, 3rd wants to spin at 70mph.
