Standard SE-R run a 16" rim. SE-R Spec V used a 17" wheel.bulld0g wrote:good price .....but I thought the SE-R rims were 17's?
Thanks NY.AD.MAN!NY.AD.MAN wrote:I would say that those are gonna look pretty sweet on the Versa, just replace the tires with some tires either from Discount Tire or Tirerack.com and if you get some quality tires, you'll never go back to cheap-o crap again!
When referring to the B15 Sentra, this is correct. When referring to the B15 (current) both the SE-R and the Spec-V use 17". That is because in the current generation, the only difference between the two is that the SE-R's are all CVT's, and the Spec-V's are all manuals.Versa Madness wrote:
You are correct. The Versa uses 4x4.5 (also known as 4x114.3mm)Versa Madness wrote:I thought the Versa ran the 4x4.5 inch pattern??
Thanks for the pic Bulldog. That looks SWEET!!!bulld0g wrote:I did a chop to see what they will look like on the V....
Anyone want to host the pics and post them for me?OV10stang wrote:I've got 17" 6 spoke SE-R's on mine right now, with 215/45/17 tires. I'll post a pick as soon as I can.
Sent to your gmail. Thanks. Sorry for the filthy car, the weather here sucks.NY.AD.MAN wrote:Yeah, email them to me...
Thanks. I like that look also.... looks like a factory option. You got a good deal though, I paid a bit more, but was lucky enough to have the dealer take my brand new stock wheels/tires in trade. (total cost: $760 mounted and balanced with Yokohama 215/45/17's, and kept the tire press sensors also.) Anything will look better than the steel 15's....lol.Versa Madness wrote:Nice looking rims on your Versa OV10stang. I like the clean look of the white car and silver aluminum rims.
You may be right about the "special edition" wheels. I was going by what the seller said, but I ran across this 2005 Sentra Special edition on CL with the same rims...shreqboi909 wrote:those r se-r wheels??? they look like the special edition wheels
