Sentra radio/clock light
Preacher Man
Car: 2008 Nissan Sentra
Hello all,
I'm having a problem I've never seen before, with my 2008 Sentra. The clock set light, on the center console/radio, will come on while the car is shut off. It wants me to set the time. I try, but the clock set button is non-responsive. Then the clock will set itself and it will turn off, after about 30 seconds it comes back on, and the process starts over again. I thought it had resolved itself, but when I checked on it this morning, the car battery was dead.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Most likely you have a faulty radio, you can buy a used one on ebay for around $50 shipped or put in something aftermarket.
In the meantime, maybe pull the radio fuse to keep it from killing your battery.
Preacher Man
04pathse wrote:
Wed Dec 26, 2018 4:43 pm
Thanks for the response. I did pull the radio fuse, but it still happens.
04pathse
Check the FSM depending on which radio or audio options you have there should be 2 or possibly even 3 fuses for the radio.
https://www.nicoclub.com/FSM/Sentra/2008_Sentra/av.pdf
You might try disconnecting and removing the audio unit/radio completely and see if the battery still goes flat.
The removal procedure is in the FSM.
Preacher Man
If I pull the radio will I need a special code to install the new one?
04pathse
If you do need it should be in your owners manual or a nissan dealer should be able to give it to you.
Preacher Man
04pathse wrote:
Mon Dec 31, 2018 10:26 pm
Thanks so much!!
