2.4niz »
https://forums.nicoclub.com/2-4niz-u70696.html
Sun Dec 14, 2008 12:04 pm
ok, took off the heat core outlet hose with engine at operating temp, after a few drips, no coolant flow whatsoever, reconnected outlet, let run for a minute then took off inlet hose, no flow from that either... I would assume that leaves the water control valve, but my haynes manual doesn't mention a control valve at all, anyone know where it is?
