nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Wed May 30, 2007 10:07 am
The ECU foam might still be an issue. It's packaging, not the computer itself. The foam deteriorates and the gas or whatever that it gives off messes with the circuitry.
The fuel pump is probably the same, since there'd really be no reason to change it for emissions purposes, as it's already rather small. However, I don't think this issue popped up on the '01s anyway.
Regardless, if you haven't had a problem yet, you're probably not a victim of either.
If you're having issues, just ask, but otherwise you're in the clear.
