Sentientbydesign wrote:Just a thought: What suspension are you running?
That might be what makes your setup look so much better.
Yes with stock ride hight they do look a little small.
I'm running 350Z H-techs that are harder and lower then normal G35 H-techs.
I also did the spring mount mod to bring the rear lower.. It should be 1.5 - 2 inches lower then stock (hard to tell because of the mod)
