chingon77 »
https://forums.nicoclub.com/chingon77-u45786.html
Wed Aug 23, 2006 10:41 am
I read the codes and the following popped up as a malfunction:P0325 Knock sensorP0120 TPS/Pedal positionP0443 Evap EmissionP0732 Gear 2 ratio incorrectP0733 Gear 3 ratio incorrectP1705 Malfunction system specific
From the manual it seems as though a malfunction in the TPS/Pedal Position P0120 will cause the the P0732,P0733, P1705 to malfunction.Is there anything i can do/try/troubleshoot before I start replacing sensors?thanks
