sensors on transmission
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
theres 2 sensors on my rb20 transmission i presume one 1 is reverse sensor but what is the other one? and which on is which?
driftmyke
come on guys i know somebody knows
driftmyke
help
s13point5
Car: 89 240sx
should be three sensors on the transmission. reverse, neutral safety switch, and vehicle speed sensor
Stealth-Z
Car: 1991 300ZX
Shift it into reverse. Use a multi meter and check continuity between the connectors. When you have "0" ohms, shift it to neutral. If the meter deflects to infinite then you have your reverse switch.
