elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Aug 03, 2003 6:32 pm
I did it myself...... You take out the ECU, do this little thing with a screw, and the computer blinks the codes......
Search around the full procedure is there, but here is a crash-course......
The passenger side kick panel is where the ECU is located (its right next to the speaker on the car, not the door).... There is a nut holding it in place near the firewall, so undo that..... The panel comes right off...... next, there is are two screws holding it on, one on top and on the bottom, on the connector end of the ECU..... undo those, and it should come out..... I had to undo the connector... Just loosen the bolt (it doesnt come out), and pull out the connector, being careful to pull it out straight..... From there, you just pull out the ECU, and plug it back in...... The plastic screw is on the front, and turn it clockwise, wait at least 2 seconds, then counterclockwise.......
Then the red LED on the ECU should come on, end then you simply count the flashes..... There is about a 1/2 second in between codes, so have a pen and paper ready.....
The long flashes are the first digit, and the short ones are the second digit....
Knock sensors are code 34, so it would look like __ __ __ _ _ _ _
Then there is a slight pause, and then it goes to the next code.....
You can also check your o2 sensors from the ECU...... I can post that if you'd like......
