sensor (?) part on air filter unit
DeltaZulu
Car: Basement Musician
Previous ower of my 240SX 90 M/T (originally from CA) damaged driver side front fender area (repaired) and air cleaner unit is also damaged. It is not in a good shape and I am considering to replace it to an aftermarket airfilter assmebly (bolt-on corn type). Then I noticed that there is a sensor (?) part mounted on the air cleaner case which is wired to airflow meter. I have gone through my Factory Service Manual but cannot find what this part is. My questions are:
Does anyone know what this part is/does?
I looked at several after market (bolt-on) air filter assembly kits but they do not seem to have any mounting for this part. Am I missing something?
Thank you in advance.
U12 2NR
probably the air temp sensor. the ecu needs it to detect high intake temps to prevent detonation. You can always drill a hole into an intake and glue it on.
DeltaZulu
Thanks for clarification. It does makes sense. By looking at original set-up, I was wondering if this part should be mounted "before" airflow sensor (which means on the corn fliter of after market kit). It sounds like I can make a hole on air intake pipe and mount on this part "after" the airflow sensor.
Thanks again.
U12 2NR
yes..mount it before the maf sensor, if there's not room in the intake pipe itself you'll have to mount it into the filter.
DeltaZulu
Thanks again for clarification.
All after market kits are designed to mount cone filter immedately before the flow sensor so, I assume I have to come up with some means to mount the temp sensor on/in the filter or to make an extention pipe between the flow sensor and filter to mount heat sensor on.
Appreciate your info.
