rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Fri May 08, 2009 5:28 pm
The Megasquirt will run any engine you want from a 1cyl to a 12cyl, I No longer get my timing trigger from the CAS, I get it from a 32-1 crank trigger will and a ford vr sensor. SO as long as you have your wheel configured correctly in the ms program timing should be dead on. Which I have varified with a timing light. But I just wonder if that sensor iss not moving my intake cam somehow causing it to start funny?I had this problem running on gas and stock ecu. It seemed like it took nothing to flood the motor with gas when starting. Now with the megasquirt setup and a ls2 coil setup with propane its kinda the same crap. Although on gas it was bad about not starting when hot. Now on propane when hot its fine. lol Idk, I just think there is a combo there gettin me. Ill get the bugs sorted.
