sensor light in a nissan 720 truck
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
st720truck
Car: nissan 720st
hey guys i need help i need the real answer to how you get the sensor light to go off once you pass the 100000 mile mark ive heard several different ways to do it but i could really use the actual way. thanks alot!
PEZi
the only way i could figure out was to unhook the wire connection
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
there is a 100,000mi light?
breadbox
89 Koop
84 720 4x4KC
could be time to retorque head bolts, like I heard was recommended around that time.
4wheelsoffury
Car: 1985 nissan 720 kingcab ST 4x4 2.4L Z24
I got my truck with 82k, and I read somewhere? that there are two connectors, 1 for a 50k warning and another for a 100k warning as you describe. I have all new sensors and if any of these two connectors are put back together I will light the lamp. The only thing that I know is to make sure you have good sensors (the warning lamp is for the o2 sensor and the oil pressure sensor/switch ) If any of these are faulty, you will probably notice.
PEZi
yeah... the light is for 100,000 miles to change the o2 sensor... even with the fresh sensor the light stays on if the wires are connected, so i just left them disconnected... that's literally all they do is tell you that its 100,000k... so.... yeah... its useless
fastboatman29212
Car: left this forum. Sold my truck.
I replaced my oil pressure sensor and to my delight, the sensor light went off! It was leaking oil from the OPS, so it needed to be done. It's easy and might fix the problem. You can find a description of how to change the OPS in the DIY thread if you need to get more info.
Link:
86-720-transformation-build-thread-t515055.html
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Most of us just disconnect the light.
djcheer
Car: 85 Nissan 720
I have a 1985 Non California Model the 2 wires are located above the hand brake under the dash (21I is for 50,000 and 100,000) and (15I is for 30,000). All you have to do is disconnect 21I because your 15I should already be disconnected. I hope this helps
Return to “Datsun 720”
