sensor comparison for air intake temp on rb26
StricNyne
ok this one is a long shot.... i just read that rb26 air intake temp sensor is the same as rb26 water temp sensor, and that was from a high pretty reputable source ( a mod on another forum) but i am a tad skeptible, i remeber my gm one looked nothing like the metal tip from coolant temp sensor, i tried to get more feedback from that forum but havent heard anything in a couple days, so i was wonderign if someone could compare those 2 sensors for me since i dont have either ti check with heh i would appreciate it i am trying to get this project on the run asap !!
StricNyne
there are 2 diff water temp sensors, he didnt state which one
Tripingram
Car: 2x s14
there are two side by side and they have different part numbers. The temp sensor i have is a different one.
StricNyne
dang, i kno there is the one with the plug, and one with the spade terminal, i was told i can run without sensor just ign wont retard when intake temp increase ohh well, the search continues that sensor is impossible to find !!
StricNyne
http://www.skylinesaustralia.c...45702
this is a new post on SAU, i will try and confirm this 100% and i will post up nissan part numbers if i can
StricNyne
and that is correct 22630 and 22630j the coolant temp sensor and ait are interchangable and use SAME plug
