If it's a FED one then it doesn't need it.Maybe someone put it on.To confirm did you check the ECU P/N?maxnix wrote:Mine is a 1995 FED and it has that sensor.
How does it add 20hp?qship96 wrote:My 96 federal model also has this sensor. It adds at least 20 horsepower!
Well then that means I can make my car with no cats and what not.It'll still pass smog?lolPaul Wall wrote:FED is less strict with emissions.
Cali is more strict on emissions.
He was joking, as in "That NICO sticker on your back window adds 20HP"unknown007 wrote:I would really like to know how it makes a FED car gain 20hp thanks.
Thanks.Hey you never know a sensor could add 20hp.Go check out ebay lol.Q451990 wrote:
Your car is apparently not the CA version. Mine is, and the only difference I noticed is that sensor, the ECU, and the sticker under the hood that mentions meeting CA emissions standards, and a different catalyst part number.
Later years got the sensor on both CA and FED emissions models, but the 90-93 did not. The bolt is standard on FED models during the 90-93 at least...
I wouldn't worry about it.
Heath
