nnicholas »
https://forums.nicoclub.com/nnicholas-u126200.html
Fri Mar 13, 2009 3:28 pm
Where to start...Codes 34 and 51...Injectors ohmed, 6 of 8 are on their way out ohming between 19 and 30, 2 at 11, KS okay...(planning a plenum job soon) I read the forums about MAF symptons (I experienced the same), running great from cold start-up in the mornings, turn it off for 30 minutes, then stumbling between 2000 and 3000 RPM over 3000 for a few minutes, then smoothing out (accelerates like a scalded dog once it gets to 3K). I ordered a new MAF which hasn't been delivered yet. Then yesterday I was pulling out into traffic and had to get on it a little, heard 2 bangs, and its been idling rough and stumbling bad between 2K and 3K rpm since, runs great over 3K.
I checked the MAF sensor plug and it was tight and clean on the inside. I cranked it again, still idling rough just like it has a fouled plug. Listening to the left side of the engine I can hear a frequent but intermittent tick like an arc, which in my old Chevy was a loose spark plug wire. I sounds like number 1 or 2.
There's a lot going on with the injectors, however could the miss be caused by something loose with one of the plugs? I'm going to check the MAF voltage tomorrow as well.
Modified by nnicholas at 7:03 PM 3/13/2009
