Sending unit
RagingPanda
Car: 78' 280Z
Can anyone tell me which one is the sending unit? The pic is directly over it facing toward the car from the rear.the top one?the bottom? middle top?middle bottom? ^_^
ricebike
2002 Quest
2005 Altima
well if u unplug the connector, & see the socket postition like this: xOOOOOX
u can probe an ohmmeter on the bottom terminals & get the following readings:
full~ 4.3-6.3 ohms (15 1/4 gal)1/2~27.7-34.3 (8 3/4)empty~73.3-84.8 (1 7/8)
others should B for the low-fuel warning light
i sux @ reading wiring diagrams + i lost the last page of the huge wiring schematic. but @ least u can trace the plug to the colored wire...
guessing this: X123456
1-top wire to the unit (connecting to ground?)2-bottom wire to the unit (warning lamp)3-???4- to the sender (color is green/yellow?)5-to the sender (color is blue/black?)6-X
can u confirm these? i didn't wanna run outside in the dark to make sure...
