I'm currently selling a 1995 240sx with a ka24det. It has 107000 on the odometer about 6k of which I've been running at 9.9 lbs of boost with no problems. The body needs work, the auto trans slips under boost from 1st to 2nd, and the oil lines leak a little right when you turn the car off.
List of mods include: Precision sc51 turbo (exhaust housing heat coated)24x6.5x3 fmic with custom made pipingPhat ka-t tubular bottom mount exhaust manifold3" downpipe with 2 o2 bungs, elongated to remove factory cat.Apexi N1 single exhaust 115mm tipTial 38 mm wastegate with 5.5lbs springhks ssq bovstainless steel oil feed and return linesported and polished head with 5 angle valve jobwalbro 255 fuel pumpmsd 35 lbs/hour top feed fuel injectorsadjustable 1:1 fprtop feed fuel railstainless steel fuel linesGreddy Profec Spec B Boost controllerApexi S-Afc II
This car would be a great candidate for a transmission swap, which I was going to do but I just moved back to iowa so I have no use for a rwd car anymore.I have a manual trans from a 95 240 that I'll throw in with the car.
Asking price is 5500 obo. Please e-mail me at [email protected] for pictures or if you have any questions.
