Sell me a starter Y33
Mopar
Car: Infiniti Q45 1998
Hello,
After having trouble with the starter for a while, my starter quit on me in the Ralph's parking lot. Now I need a starter
It's a 98 Q45, if anyone can sell me one that they have ASAP I would really appreciate it! My Q is disabled
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Why not an autoparts store?
Mopar
I want OEM plus they don't have it in stock
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
You can get from Joe, InfinitiPartsUSA.com, 1-888-216-5328 for $289.70. They have a flat rate $5 shipping fee for this month. I checked Kragen, price range from $121 to $330 while at AutoZone, it's $244 (less $85 for core). Your call which one you want.
Rod
tmorgan4
Car: 2000 Nissan Pathfinder
Any idea if a starter from the earlier models are any different? I have a starter off a '92 I received with some parts that I won't be using.
lakeq45
Car: 01 Infinity Q45, 00 Honda Insight, 96 GMC Sonoma
This brings up an issue that I had been meaning to post about. I am currently on my 3rd starter for my 01. The 2nd lasted a little more than 18 months. These have all been OEM installed by the dealer in my area. Even when new, about once a month the starter will not "engage" properly and grind the flywheel.
Any other Y33 owners have starter issues or is there anything that could be causing this. As soon as I can get to an AutoZone I plan to have the battery tested since it is getting some age on it. Could a bad spot in the teeth of the flywheel from the first starter going bad be an issue? The one time that the car stranded me I was actually sitting in the dealers lot picking the car up from an oil change, but my wife and son are the usual users of the Q so, the starter issue always nags at the back of my mind.
gammer_ghn
yes you will have that problem once you engage the starter while the engine is running i havent had that problem and im up to 102k miles finally and ive driven mine since 63k miles use it correctly and it will serve you for a looong time and mine is a 99 just in case you guys are wondering....
lakeq45
Ok...I may not be a mechanic, but I do know that the starter will grind when the car is running. I was speaking of when trying to START the engine.
gammer_ghn
lakeq45 wrote: Ok...I may not be a mechanic, but I do know that the starter will grind when the car is running. I was speaking of when trying to START the engine.
yes your son and wife might make that mistake since i let my mother drive mine and in 3 hours she did it 2ice since my car runs so smooth and i have been close to doing it a few times but neever actually have thats what i ment you start missing teeth and the starter it self could start going bad because of that im just saying that and if your grinding the way you are saying it should be because its loose or least likely your flywheel has teeth missing...............
