ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Mar 07, 2011 11:44 am
Use a bent tool. Bent at 45 degree with a wide base but thin enough to fit within the spurs of the adjuster wheel. If you were able to turn the adjuster the wrong way force this adjustment tool against the oval hole opening and use the leverage the tool makes between the spur and the hole edge. Do not push the actuator into the wheel assembly as you need tons of stroke power to turn that adjuster.
With the bent adjuster in hand, balanced to turn just the adjuster the right way and in your mind make certain that you are turning the way to loosen the shoes against the drum, make each move deliberate and try for a very small turn. The keep at it the adjuster can withstand the metal bar pushing it around.
You cannot afford to get mad at it, take a 5 lb club hammer and with a solid smack on the drum listen for the pressure to come off the drum. Make sure you turn the right way with the tool planted correctly and your movements firm and direct.
If after many attempts and nothing...take a break... find a curved piece and try capturing the adjustment assembly and pull the whole thing towards you away from the centre of the axel, then retry the tool.
If nothing works, you may have to bust open the drum as a last resort.
From experience I know what your going through that is why I don't want you mad at it.
As a recoil wrap I have used an old expansion spring to pull on the assembly, also look to see if you can spot the holder that keeps the spur wheel from turning, it is possible it is now bent making more work for you.
Good luck, be patient, are you doing this work on the floor or are you on a hoist?
