self diagnosis on active not working
velvet hammer
Car: 1990 jdm Q45a 60000miles on the clock
Trying to run error codes on my occasionally active Q , but after turning the height adjustment switch ten times in ten secs the activ sus light didnt do anything??Is the procedure different on a 1990 model?Thankyou guys
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
its actually more than 10 times..
Does your ACTSUS light come on? is the thing full of fluid? Sometimes it wont come on if the fluid is low?
Jehangir
Car: 1992 Infiniti Q45A
the way i check mine is by, turning my ignition swith to on without starting trhe car. Then occiliating the switch ten or more times between "hi" and normal. Wait a couple of seconds and watch the flashing lights on the dash.... you know the first couple of lights indicate the first digit. and after the pause the next couple of lights indicate the second digit in the code. Im sure a lot of this is redundant. But, email Keith he's the Guru of all active issues. What makes you think you have a problem?
velvet hammer
I double checked my fluid level and it seems ok, tried the procedure again and again but it does nothing. Im wearing out my height controller switch but getting nowhere
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
I had the same problem. Never fixed it, I converted. However since I have heard that people have had success after swapping out thier active computer. Replaced and alternator or battery lately? Seems to be a common thread on fried active computers
velvet hammer
Drove my Q45 for 30 mins today and the active sus was working really nicely but i had no power steering?? I need help. I wish there was a competent workshop i could trust.
goody90q45
Car: 1992 Infiniti Q45 (sold)
velvet hammer wrote:Drove my Q45 for 30 mins today and the active sus was working really nicely but i had no power steering?? I need help. I wish there was a competent workshop i could trust.
Power Steering controller module? 3" X 3' X 1" box under the dash. I haven't looked it up in the FSM but I bet there's a page on troubleshooting it. I believe it's a module specific to the active. (BTW- I have one if this turns out to be the problem). Good luck.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
First thing to check is the pressure developed by the PS pump side of the combo active/ps pump. Several owner I know of (including my wife's car) have experienced unexplained sudden loss of pressure delivery of the PS pump. It was only after 3 R&R and teardown/inspections of her pump I had a 'eureka' moment. The PS pump is a conventional sun & ring gear/crescent pump--extremely robust and reliable-bullet proof except for gravel. What happens: IF in its previous life the PS oil was not changed regularly and allowed to oxidize any, it attacks the +/-7" dia O-ring that seals the outside end plate against the removable housing end. If this 'sensitized O-ring ever gets exposed to air, even for an hour or less, it rapidly shrinks in cross section and hardens. This may happen when you try to drain and flush all the PS fluid, or fix a leaking suction pipe O-ring seal. Then on restart, the shrunken O-ring allows the end-plate to move out slightly-creating a large internal by-pass in the pump housing. Result--low pump pressure delivery.
Fix: either a new pump install or remove the pump, remove the back cover, remove the shrunken O-ring and add several layers of teflon tape into the groove to make up the loss in O-ring cross section, reassemble,reinstall. Hop eit works.
