Self-diagnosis for the 240SX ABS System.
Articles, modifications, maintenance, DIY's, how-to's and general information for 240sx owners.
Self diagnosis for the 240SX ABS System.
The ABS Controller is in the rear of the car on the left (driver's) side. It has an L.E.D. to flash and offer codes to help you determine what's wrong.
Drive the car for at least 1- minute at 19 mph or above. Leave the car running (parked of course!) and count the number of flashes on the Controller L.E.D. When the repairs have been made (and the car turned off and restarted), repeat the Self-Diagnosis procedure. If there are more than 2- circuits malfunctioning at the same time, the L.E.D. will flash for only one of the problems. After that has been fixed, the L.E.D. will now flash for the next circuit. And so on.
The L.E.D. codes are as follows:
1 = Left front actuator solenoid circuit.2 = Right front actuator circuit.3 = Rear actuator solenoid circuit.4 = Same as 3.5 = Left front rotor sensor circuit.6 = Right front rotor sensor circuit.7 = Rear rotor sensor circuit.8 = Same as 7.9 = Actuator motor, motor relay circuit.10 = Actuator solenoid valve relay16 = Control Unit
Note: If the Warning Light activates and the L.E.D. is OFF, check the power supply or ground circuit for Control Unit.
Certain driver induced faults, such as not releasing the parking brake fully, excessive wheel spin on low traction surfaces, high speed acceleration or riding the brake pedal may set fault codes and trigger a warning lamp. These induced faults are not system failures but examples of vehicle performance outside the parameters of the control unit.
Return to “240sx Articles”
