CoupeVQ35CVT »
https://forums.nicoclub.com/coupevq35cvt-u137499.html
Tue Jul 10, 2012 4:15 pm
My OEM tires wore out around 26-28K miles (in fact were pretty much past due for a change). I finally got new ones as listed in my signature below, Falken ZX512 I believe they're called. I'm on my 3rd set of tires, 2nd set of the Falkens. The first ones wore out in 30K miles, quite noisy and had feathering issues (uneven wear causing rumbling type noise at all speeds). I thought it was due to misalignment from the start, despite having them rotated every 6k miles and having an alignment done at least twice.
I for some foolish reason bought the same Falkens a 2nd time, @ barely 59-60K miles, and this time made sure everything was aligned right. Even tried to have them rotated @ 3000-4500 miles instead of 6k. Unfortunately just past 3-4K miles they were becoming noticeable louder, and the dealer said they see feathering around the outter and inner tread area again... So at this point I am skeptical of any tires after paying $800-$900 twice now for the same results... After a bit of googling, it would seem that most single direction tread performance tires will eventually have this wear issue I've experienced, possibly since they cannot be swapped around to the other side of the car, only front and back.
I will give my tires another few thousand miles and will be on the lookout much like you for something better.
