jfachatz »
https://forums.nicoclub.com/jfachatz-u143853.html
Mon Mar 01, 2010 9:28 am
On my 99 Q45t, I did some home grown repair work on a cracked driver's headlamp housing. In order to remove it I had to also remove the air filter box and some of the duct work heading back to the engine air intake. While moving these things out of the way I loosened a braided ground from the driver's side of the engine that ends in a white modular plastic connector bolted and connected to the driver's shock tower. During reassembly, i could not recall where the gold circle end of this wire needed to connect to at the engine end. I connected it to a metal support for the air duct. Within 2 days my SEL light came on with error codes for both bank's knock sensors being bad. Is it possible that my attaching the ground in the wrong place on the engine could fool the ECU into thinking the knock sensors are bad or am I just dreaming and I need to prepare to replace both knock sensors? Thank you! -Jason
