elwesso wrote:He said that the car had the spark plugs replaced at 176k..... However he said the no 8 spark plug was not replaced because it was seized in place . . . Ill assume that the plugs were original at 176k but maybe not.. If it were me I would throw a breaker bar on my ratchet and keep pulling... I want to try and fix this for the guy but I dont if I want to mess with it... Stripping out a plug on the head would be BAD NEWS . . .
The old standby has always been torch the head to expand her, then wrench out the plug - NOT GONNA HAPPEN w/the deep set plugs on a Q head w/o major disassembly - if you insist on the thermal shtick methodology - bimetallic expansion games can be tried w/warmed head and slipping a socket from the freezer over her trying to get the chill to shrink the plug and cause a microscopic break between the threads and the corrosion holding everything together -
Get a can of PB Blaster. Spray it on and wait several cycles ......should break free with ease....Unless some person of relatively high IQ cross threaded it!!! Go slow and easy! Rock it back and forth, trying to get a 1/4 turn extra each time, and going all the way back in each time. Even better than the Parker Brothers (PB) "Blaster" penetrant, which is very good, you might also try Kroil - a product that seems to find a lot of favor in the aircraft industry which uses a lot of aluminum. I have had no luck finding Kroil at any parts places, but you can order direct - they have a web site - do a search for Kroil. (Check w/your local reloaders)
Also - take note of the suggestion to use the penetrant several times over the period of several days and through several heatup/cool down cycles. Don't bother with stuff like WD40 and the usual stuff on the discount auto parts stores shelves - useless for serious work like this. And when removing, do the out 1/4, back in and out a little further. etc. routine, spraying additional penetrant each cycle. – Don’t worry man - absolutely no hydrolock potential if you drop a cloth/absorbent material around the plug threads to mop up once you get her broken and finally moving.
a SAD REALITY is threads on both the heads and the plugs can literally gall and weld themselves together if just left "to their own" for 100K plus - and you're approaching double that - but cheer up - I have NEVER seen a failed removal attempt w/a pneumatic impact gun (if they weren't cross threaded) - but I’m no pro
Do the typical minimal damage first method - run down the torque setting on a pneumatic impact wrench and let modern mechanics work for you - next, a couple of heat/cool cycles using penetrating oil, then go with a breaker bar, and a bit of impact adjustment (tap her w/a hammer on the socket/extension sitting cleanly on the plug) - next is a cheater pipe (along w/paid up insurance), and then we get to the serious who gives it up first - you or the threads - Rip that Sum***** out and ta hell w/the consequences - although no damn fun, Helicoiling an AL head can be done
