seized motor problems
jdm_connection
i have 1989 240sx ka24e motor well the car doesn't start so i recharge my battery ,and took out my starter and tested it ,so far everything work ,a person told me to check the crank by turn the crankshaft to see if i spins,,you can almost get a full rotation and then it stops clock wise,if you go counter clock wise it will also stop at full turn ..
Zilverado
Car: 1992 Nissan Pathfinder SE 4wd
So it is your engine, eh? (Responded to your earlier post).
Sounds like something might be broken somewhere. Maybe a broke/bent valve preventing one piston from reaching top dead center? Does it make any sound while you turn it or when it stops? Metal on metal clank or anything?
Never had this happen to me, so not exactly sure what it could all be...
jdm_connection
no sound of metal to metal
180fan
Car: 89 fastback
Sounds like there's something that's keeping it from rotating. It's always around the same spot right?
