JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Sat Feb 11, 2006 11:21 am
"bushings"?
There should be no bushings inside the brake caliper. There is a piston that is surrounded by the seal/boot. The piston is probably messed up, for sure. If you look long and hard enough, you could probably find a caliper rebuild kit, and a new caliper piston, but for $160 each, go with new (or rebuilt) calipers.
Ive rebuilt a caliper on my now deceased Porsche 944, but only beacuse it was leaking from the seal, and being a Porsche, the caliper itself cost mucho denero. I have seen MANY seized calipers in my time, and do not recommend trying to rebuild one, since replacements are so available and cost effective.
Replacing a caliper is quite easy, if you can replace pads, you can replace a caliper. Only thing is, once you are done, you have to bleed them.
