[quote=" Out of desperation, I took the drivers side kick panel back off to see if the fuel pump relay had somehow become disconnected. All this time I sensed that I could smell gas fumes, so for the last try, I left the pump relay disconnected, and low and behold, the car fired right up. Instead of letting the car die from lack of fuel, I shut it off, reconnected the pump relay, and wouldn't know, it wouldn't fire at all just like before. SO, disconnect the pump relay once again, and it fired right up, only this time I got the relay reconnected before the engine died of fuel starvation. It has started every time since (over a dozen start attempts) and I took it out for a road test and it ran perfect except for that still high idle issue. My question is could the fuel press. regulator be going bad, allowing TOO much press. to the injectors, causing flooding problems?"
I really need some expert advice, please. For the third time, I've gotten the car to run just fine, fires up every time.....until I button up the fuel pump relay and reinstall the kick panel. Each time I do this, it floods out (I say this because I can smell gas fumes almost immediately, and the car won't fire on even one cylinder let alone six). I remove the kick panel (again), unscrew the relay mount screws, disconnect the relay plug, and damn if it doesn't fire right up. If I reconnect the relay plug before it quits, I don't have any problem with it restarting EVERY TIME. Do I need to run around with the kick panel off and the relay just laying there on the floor board?? REALLY frustrated here????
BTW, I know my fuel lines are connected properly because I took some before pix before even attempting to tear down the intake plenum and I used those pix to reassemble everything......
Thanx in advance, Steve
