Seems like nobody can answer this correctly.
GBSilviaS15
I have a 95 240sx Zenki... Are you still following this?
Okay I want to change the front end into a Kouki. Instead of getting the stock Kouki parts, can I get like aftermarket body kit parts instead?
For instance, bomex fenders, bomex hood, bomex front bumper...
Other than fenders, hood, bumper, what else would I need?
I know I need the Kouki headlight brackets also... Is there anything else? Bumper support?
PGBrian
jesus.BOMEX doesnt make good stuff.stop thinking about it.
MSports makes fiberglass fenders, bumper, and hood.then you will need to find headlights, corner lights.
hannibal
Car: Red Line to Glenmont
sounds like you already know the correct answer.there are plenty of threads about whats required for zenki to kouki swap. As long as you have all the parts (aftermarket or OEM), you should be good to go.
R240NA
Bomex does not make fenders or hoods.
SoCalS14
Car: My car...duh
I have to admit I was unimpressed with there product (Bomex)
Bunta
Car: S14
theronin
GO AWAY
