no, wheels can shake at different speeds. i've experienced shake at one speed and total smoothness beyond that speed, and it was wheel balancing that was needed.Shad0wXCalibur wrote:Well if it were tires, I would think it would vibrate more and more the faster I go and do it wether I'm pushing the gas or not. Not just between 40-50 mph and only when I'm accelerating. I guess I could rotate the tires and see what happens though.
Tire vibration is a frequency issue, so it's common for vibration to only present within a narrow range of speed (5-10mph). I would start by getting the tires road force balanced. You can even try one axle at a time if you want...if you think it's the rears, just do the rears and see if that fixes it.Shad0wXCalibur wrote:Well if it were tires, I would think it would vibrate more and more the faster I go and do it wether I'm pushing the gas or not. Not just between 40-50 mph and only when I'm accelerating. I guess I could rotate the tires and see what happens though.
