pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Sat Dec 25, 2004 2:00 pm
well, you can buy coilovers with different spring rates installed but you have limited options for the rates and once you buy them you cannot "adjust" the spring rate, just the ride heigth and the dampening rate. you also DEFINATELY want to stay away from these "coilover conversion kits" that are sold on ebay and various sport compact catalogs the spring rates these kits come with would feel harsh in a 4200 pound caprice lat alone one of our cars. I will put it this way, bone stock our cars have a 112 lb/in rate, I am running 175 in front and 150 rear as recommended on the 240sx.org site, most coilovers like teins are around 225-250 but it depends on the type you buy, the "conversion kits" you buy out of a catalog are usually 450lb front and 250-350 rear so you can imagine what the ride is like ( i used them before doing my own conversion and most bumps will send you airborn ) again IMHO to get the best ride do the conversion like on the 240sx.org site and play with the spring rates the springs I used are about $40 each shipped so if you want to change the rates it is quite cheap to change the springs for the mounts, springs, and sleeves with nuts I probably have $300 in my setup and with this setup you can use factory style replacement struts like the popular kyb agx or koni's both of which have adjustable dampening rates to match the springs you pick. this setup gives you the most flexibility and a decent price.......
