Using cfm is so ambiguous because it varies in density with temperature and barometric pressure and other factors.Modern OBD2 ecu generate an accurate air flow in grams per second.
"with air flow increased to 320 grams per second [405 HP at 6,000 rpm] in the '02 LS6, up from 304 grams per second of air flow in the '01 LS6."
One might conclude that 0.79 grams per second of air is needed per horsepower.
http://www.superflow.com/suppo...s.htmh ... amtest.htm
"""170 Gm/sec works out to 300 cfm (and about 205 HP) (at sea level), which works out to 84% or so VE--454 grams = 1 lb. (conversion constant)0.075 lbs./cubic foot = typical sea level density of air at a reasonable temperature
(1) therefore 170 grams per second /454 grams/ lb. = .374 lbs./sec
(2) therefore, .374 lbs./sec. x 60 seconds/minute = 22.47 lbs./min. (of air, number used in (3) & (4) below)
(3) therefore 22.47 lb/min. / .075 lbs./cubic ft. = 299.6 cubic feet/min.(cfm) of air.
(4) therefore, 22.47 lbs./ min. x 60 min/hour = 1348 lbs/hour of air.
(5) therefore 1348 lbs./ hour / 13.5 (typical WOT a/f ratio for an NA engine) = 99.87 lbs./hour of fuel
(6) therefore 99.87 lbs./ hour of fuel/ .48 lbs. fuel/ brake horsepower hour ( a pretty typical brake specific fuel consumption figure for an NA engine) = 208 Horsepower.
35 lb/hr or 370 cc/min injectors = 4.4 grams fuel per second at 43.4 psi at 4,020 rpm [67 rps] x 4 =268 injector pulses of 11.0 milliseconds each but only 9.5 millisec of full flow and 1.5 millisecs of ramp up and shut down.....call it 10 millisecs of flow= 118 grams per second x 60 x 60=.....................
