jcberb wrote:Brandon, with your install, did you retain the ability to adjust the headlight with the OEM adjustment screws or were the projectors aimed and set in place? If you did, would you mind telling me how to remove the reflector from the housing...
I am preparing to install a pair of TSX but wish to do so while retaining the OEM headlight adjustment.
Thanks-joel
Bina glad everything got there ok and your happy with them so far, cant wait to see them installed.
in terms of the retrofit, all of the ones i do use the factory levelers. basically once i mount the projector inside the housing i make small adjustment with individual screws/springs that hold the projector to the bowl. basically side to side and height so its not aimed at the ground. then the factory adjuster is used for up and down. no matter where its aimed your probably going to get highbeamed by older cars with halogens, my factory hids i was getting highbeamed. to take the housing out of the light once you have the glass off, unscrew the adjuster so the bowl is aimed right down and until it wont turn anymore. pull the outside of the bowl where the highbeam is out and towards you to pop the first clip. then where the adjuster is use a long screwdriver (flat) and push it into the plastic clip where the hinges are on it and pull the housing out. then the side one just bend the housing to the side and it will pop off and thats it. also the piece that screws into the glass sometimes needs to be modified or else the projector will hit it
