Sedan middle console LOOSE!! HELP!!
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
I'm having a serious issue with my center console where your arm rests. On the left side next to the seat belt it feels tight with no movement but on the right side its extremely loose and if I slightly lean against it while turning it snaps out of place. I can grab the right side of the console from the back and pull and it moves with ease. Does anyone know where or how this is fastened down or how to fix it?!?! thx
Bad News
your still in warranty right? the answer is as close as your nearest friendly dealership
milkacaduke
on the bottom of the console at the passanger seet there should be 2 screw holes 1 on each side.
maybe there's a screw loose
maybe it might help
altimacoupelvr
Car: 2008 Nissan Altima Coupe 2.5S Code Red/ Blonde Interior w/ Convenience Pkg.
that happened to me too. it was just a screw loose on the passenger side. if you push the passenger seat forward its easy to get to.
cuzzbubba420
Thanks!! I'll check it when I get off work!!
