SEDA Drift event in Atlanta! 'Lucky Slides'
Exar-Kun
Car: 2005 350Z
Clickon Flyer to see full size..
All day practice drifting event at:Atlanta Dragway500 E. Ridgeway Road - Commerce, Georgia 30529Registration & Tech: 7:30am - 8:30amMandatory Driver's Meeting: 8:45am (DO NOT BE LATE IF YOU PLAN ON DRIVING)Cars on Track: 9:00am - ??:00pmPre-registration $75.00 for Members and $110 for non-membersDay of Event $100.00 for Members and $135 for non-members(The reason there is a difference in prices for Members versusnon-Members: To drift at a SEDA Event you have to be a member and theextra $35 charged to you is only done once a year and is good for afull years Membership with SEDA and all of it's Events, Meets andGatherings.)Unfortunately this is ONLY for Drivers and one passenger pervehicle. No Exceptions!! Because of Insurance reasons our venueis playing it safe and keeping the spectatorship to a minimum.
Preregister through PayPal to [email protected] . In the"Email Subject" window put Lucky SlidesIn the notes section you can optionally put something about LuckySlides at Atlanta Dragway if you want to ensure that there is noconfusion on what the payment is for.
NOTES:1. There will be a 40 DRIVER MAX. To make sure that everyone getsPLENTY of seat time. Once we reach the 40 DRIVER LIMIT THAT'S IT.
2. ALL DRIVERS NEED TO ARRIVE BETWEEN 7:30-8:30AM. If you are paid anddo not arrive by 8:30AM, your registration will not be accepted. Thiswill be 100% enforced.
3. General tech inspection guidelines -- a. Battery tie down -- you must have a strong battery tie down(preferably metal). Bungee cords are no good. Do not even bothergetting in the tech line if your battery is not secured well. Batteryboxes must be similarly secured.b. Seat belts -- you must have a functional 3 (or more) point seatbelt that is securely fastened.c. Seat bolts -- make sure all your seat bolts are tight and present.You will not be able to drive with less than 4 bolts holding your seatto the chassis.d. Lug Nuts / Studs -- you must have all lug nuts and studs per wheel.3/4 or 4/5 lugs/studs fails tech. No exceptions.e. Wheel bearings -- must not exhibit excessive play.
Any Sponsorship information can be sent to [email protected] [email protected]
For more info goHERE
Nismo_Freak
Car: 89 Nissan 240SX
This isn't the drift forum ... Chet.
Exar-Kun
Car: 2005 350Z
True...but I like to abuse my power once in a while. :pPlus, I cleared it with Greg anyway
