my12by60 »
https://forums.nicoclub.com/my12by60-u258835.html
Tue Aug 16, 2016 12:46 pm
I was working on my turn signal switch which will not self-cancel after a left hand turn. So I took the steering column apart and removed the turn signal switch so that I could see how it works. Looks like the switch has a spring loaded plastic tab that pops closer to the steering column once you activate the turn signal. Then the steering column has a notch on it which trips the plastic tab and returns the signal to its neutral position. So while studying all of this while moving the steering wheel, the steering wheel locked in the right turn position. Once I put things back together, I can't now get the key to move to the right to allow me to start the car. Do I just need to fight the steering wheel a bit harder to get some movement or have I tripped something in the security system that I don't understand?
