Security System-Car won't start sometimes
kristenleea
Car: 2004 Infiniti G35
Hello! New to the forum, Has anyone had a problem with their car NOT starting unless they use the car's keychain clicker? I am thinking it's a security system issue. Once I get into the car and it doesn't start right up, If I use the keychain clicker to unlock and lock the car while i'm in it, then it usually will start, but sometimes it takes SEVERAL clicks to get it to work. I checked the Battery and that was fine, so my guess is it has something to do with the Security system. ANy Insight would be greatly appreciated! Thanks in Advance!!~Kristen
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
Welcome to the forum. I'll bump this back to the top so it will get the attention it deserves. It seems to be a little slow today, but I'm sure it will pick up a little later today.
Sounds like an alarm issue to me too. Maybe one of the techs will be along and help with your issue. Again, welcome.
telcoman
kristenleea wrote:Hello! New to the forum, Has anyone had a problem with their car NOT starting unless they use the car's keychain clicker? I am thinking it's a security system issue. Once I get into the car and it doesn't start right up, If I use the keychain clicker to unlock and lock the car while i'm in it, then it usually will start, but sometimes it takes SEVERAL clicks to get it to work. I checked the Battery and that was fine, so my guess is it has something to do with the Security system. ANy Insight would be greatly appreciated! Thanks in Advance!!~Kristen
When you say you checked the battery, how did you check it? Even if you used a digital voltmeter to measure the voltage, I would still replace the battery as a first step.
I had an intermittant problem with my remote and after I replaced the battery I had no more problem.
Telcoman
telcoman
I forgot to say welcome to NICO
kristenleea
I checked the Battery at Auto Zone. I have an appointment with Infiniti on Monday, and you know how Murphy's Law goes, I haven't had an issue with it since yesterday-although it happens all the time. Thanks for the Replys!!
telcoman
kristenleea wrote:I checked the Battery at Auto Zone. I have an appointment with Infiniti on Monday, and you know how Murphy's Law goes, I haven't had an issue with it since yesterday-although it happens all the time. Thanks for the Replys!!
kristenleea
On the back of my remote it specifies use battery CR 2026If you have a radio shack near you take the remote with you and they'll even put the new battery in for you. Might save you a trip to the dealer that may very well charge more for the battery unless you are under warranty. Perhaps it might be a freebe but who knows? Very often a marginal battery will cause the remote not to operate when the temperature drops?
Good luck
Telcoman
kristenleea
Thanks for the tip, I meant to say I checked the Engine Battery--Not the Battery in the remote, but that is probably a good idea to change that one too. Thanks!
JimW
Car: G35 Coupe
This happened to me once (3 days after I bought the car). Infiniti looked at it, couldn't duplicate the error, and it hasn't come back to haunt me yet (knock on wood). There's a little bit about it in the owner's manual, too. I think it says that sometimes other wireless things can interfere with the security encryption signal on the keychain.
telcoman
kristenleea wrote:Thanks for the tip, I meant to say I checked the Engine Battery--Not the Battery in the remote, but that is probably a good idea to change that one too. Thanks!
I assumed you were having a problem with the remote. Since your vehicle is an 04, if both the engine battery and the battery in the remote have not been changed, my advice is to replace both. You certainly don't want to get stuck on some dark and stormy night.
Telcoman
