Security Issue?
jaksonn3
Car: 1990 nissan 300zx
hey everyone i have had a 90' 300zx for about a year and a half i just now started having problems starting it.I turn the key all the lights turn on everything works but when i go to crank it nothing happens no click no turnover nothing. i thought it might have been a security issue. the security light would flash non-stop i finally read to hold the key in the unlock position for a few seconds and it should reset itself. the security light now:
1. when door is closed and lock - the security light stays on
2. when door is closed and unlocked - it stays off
3. when door is open (unlocked) - the security light flashes
( CAN ANYONE CONFIRM THIS IS THE CORRECT SECURITY SEQUENCE )
but even after reseting the security it still wont crank. has anyone had this issue? or any suggestions on what to do? t
the next thing im doing is taking it to the shop to get the starter and all of its components tested.
just to let you know im not much of a mechanic and i would greatly appreciate the help!
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
A quick way to tell if it is the anti theft is to disable it completely.
http://www.youtube.com/watch?v=bo5bkayw ... ata_player
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
^ what he said
Do that and let us know what happens
jaksonn3
thank you for the advice im about to go give it a try. i will give everyone an update when im done. thanks again!
jaksonn3
Update: i managed to disable the alarm system thanks to the video help, but the problems still occured and wouldnt crank so next thing i did was check all the starter components come to find out somehow a stick jammedoso up in the starter and pulled a wire loose and kept it from cranking. My luck. But now she is good to go
t.mcginley.jr
1966 Ford Mustang
jaksonn3 wrote:Update: i managed to disable the alarm system thanks to the video help, but the problems still occured and wouldnt crank so next thing i did was check all the starter components come to find out somehow a stick jammedoso up in the starter and pulled a wire loose and kept it from cranking. My luck. But now she is good to go
It's always the little things... :rotfl
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Lol, nice. I would still leave the security unplugged.. but thats just me. It has a record of issues.
H1tman
Car: '90 300zx 2+2 Azure Blue
:dblthumb:
