Pento240sx wrote:I see. Well I will need Outdoor and maybe a few indoor wireless cameras with a good battery life. All of them have to be night vision or good low light settings and good video quality. The budget is around 10,000. To tell you the truth I don't know much about cameras, but I'm learning. I appreciate your help
Ok CCTV run off of standard 110V DC current not batteries. They utilize power supplies much like those used for chargers. With a $10K budget you will be able to get some fairly higher end camera's. Deduct $1-2K for your DVR. Your standard indoor dome or bullet camera run from $150-300 a piece. Tamper proof domes are usually in the $500 range and they generally have a really good color picture and the IR is of excellent quality. Exterior camera's are more expensive due to their nature but still not as expensive as most think. For $8K (remember the DVR will be roughly $2K) can get some pretty awesome camera's and still have plenty left over for the Siamese cable and BNC connectors need to make it all work, plus be able to pick up a 12/24V power supply to power up all the camera's.
Camera's systems are the easiest systems to install, but they are very labor intensive because you have to pull a Siamese cable from each camera location to your head end (where your DVR and power supply are located). Plus if you are planning to run it over the internet for remote view ability you will need to run a Cat 5e from your DVR to your network hub.
You're going to need a BNC crimper to put the BNC's on each of the Siamese, If you are running to outdoor camera's you'll need a hammer drill and a 1/2" or 3/4" masonry bit to drill through the side of the building, plus a 1/4" masonry bit to drill the holes for the anchors to screw the camera's in to the wall.
Have you ever run wires before? It's generally a 2 man job depending on the size of the building that you're running the wires in. I can run a fairly large building by myself as long as I have a green stick and ceiling doesn't fight me, but I've been doing it for 3+ years. As far as adjusting the camera's to get the best picture possible, that is definitely a 2 man job unless you have a portable monitor.
My email is in my profile, please feel free to email me and I can totally help you out here. Under no circumstance DO NOT go cheap and get one of those CCTV systems that COSTCO sells, they are garbage and will haunt you when it comes time to trouble shoot and will wind up costing triple what you would pay if you did it right the first time. Look into PELCO and SPECO camera's, they are relatively cheap, have really good pictures, and are of good quality.
