security 93 g20
habharley06
Car: 93 infiniti
No security light vehicle will not crank, unhooked door, hood and trunk switches, still same problem, disconnected battery retry no crank, this is a 4 door just disconnected front doors. switches in rear doors...
nametakennow
Car: '06 MINI Cooper S
I'm not sure I follow what you're saying. By security light, do you mean the dome light that comes on when you close the door?
Dead battery, bad battery cables or grounding, blown fuse would all be good places to start.
Autoquick
habharley06 wrote:No security light vehicle will not crank, unhooked door, hood and trunk switches, still same problem, disconnected battery retry no crank, this is a 4 door just disconnected front doors. switches in rear doors...
There is the security disabler and (For Automatics) transmission position sensor. Must be in park or neutral. That will also prevent cranking.
cwolv
Car: 93.5 kj1 p10
i second the dead battery. if the battery isnt dead try it in nuetral, could be the safety switch like Autoquick said. i have to start in nuetral regularly.
