M4T5 wrote:Ken...lol...I'll some it up for you. It's kind of like TM (Torque Management).Pulls away power to save the vehicles vital components! Would be great if UpRev figured away to pull some of the TM or Calculated Load Value parameters out of the ECU programming.I know TM can be removed in percentages on other vehicle makes. Hell, a good tuner can take out 100% TM if that's what the customer wants. Most good tuners however will warn you or avoid removing 100% of TM. The most TM I ever had removed from an ECU program was 65-75%. Keeping some TM in an ECU's programming will prolong the life of the transmission and other powertrain components.Now, if I had a standard transmission, I would have 100% of TM removed from the programming.Anyways....I think TM is roughly the same thing as Ken's Calculated Load Value is. At least it is based on the same principals.
J
To a point it is the same, Torque Management is a GM term, and it is only previlent durring shifts. Good tuners can do this - yes - most GM handhelds can and you should definitely think about beefing the trans and Torque Converter first. 6 speed vehicles do not have Torque Management, it is only for Automatics.
Nissan's "Calculated Load" is completely different in the fact that it is constantly adjusting based on airflow and how far the ECU can adjust.
UpRev will reprogram the adjusted values to bring calculated load back to 100% rather than having it at 110% - 115% or any higher.
To give you an idea, with just the Airbox Mod and the TB coolant bypass, I was at 103% ~ 104% caculated load value at "Idle" meaning that at my given altitude, air flow and air inlet temperature that technically I was flowing 104% more air than the factory had originally inteded as an optimum setting. That was verified using UpRev's Cipher cable that can read Nissan's specific code, not a generic scan tool. Cipher can read and data log at 20 times a second on each and every parameter, versus 1-2 times a second from a scan tool. OBD2 protocol does not necessitate any higher resolution, but nissan's proprietary code reads much faster.
When my car is tuned - we'll see where I am at now concerning calculated load with the exhaust setup and the new intake. I had hoped it to happen much earlier, but life happens.
