Secret to thermostat housing?
Cpt_Impossible
Car: G35 6MT
Hey, I am about to replace the thermostat in my RB20 and I was wondering if here was some trick to getting that third bolt that sits under the intake manifold. The other two look really simple but I dont see a good way to get at that third one. Anyone have any experience here? Do I have to remove something else to get at it?
Thanks
skillzilla
If Im not mistaken I used either a wobble socket and an extension or an open-ended wrench and turned it 1/30 of a rotation every time. Sux either way but it is possible.
stldrifts13
Car: '94 BMW 325i
skillzilla wrote:If Im not mistaken I used either a wobble socket and an extension or an open-ended wrench and turned it 1/30 of a rotation every time. Sux either way but it is possible.
yeah, what he said. it's still a pain in the *** to change it with the engine installed.....
Carl H
use a uni-joint on the socket, works wonders...as for reinstallation make sure you use grey gasket ONLY that is warm, cold gasket maker will break stuff.
Cpt_Impossible
Car: G35 6MT
Cool, thanks guys, got some grey gasket, oem Z32TT thermostat, water wetter and oem Honda coolant. Hopefully this fixes things.
