I did some searching on this and pulled up a couple indefinitive threads (
zerothread?id=138059 for instance). Ryan, did you ever get around to testing the effects of closed vs. open on a dyno? Adjust them to open via the SDS? Scrap the project ??? I'm thinking I'll probably remove them but if there's evidence of a real gain by keeping them I will. If I do remove them, what's the best method?? Can I remove the plates only and leave the shaft (cheap/easy)? If I remove the shaft do I need to plug all the holes or only on the ends? Thanks guys!
