Secondary Location for fuel filter on a Q41??
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
The brackets which hold the fuel filter cover on my Milwaukee car are rusted to hell and back. Consequently I'd like to locate the filter elsewhere.
The most obvious (and easiest to access for future changes) choice would be under the hood but those lines are probably too high psi. Correct?
Anyone ever put it in a different, safe, secure spot?? Any suggestions appreciated. Of course lectures on not buying a rusty car make for entertaining reading and provide a great opportunity for chest thumping as well. If that's your thing, knock yourself out. I'll just roll my eyes and fetch another frosty pop.
Rusty.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
I think that you should cut the offending mass off of the car and buy the brackets and assembly off my parts car. Clever huh?
oldmako
Certainly not a bad idea Andy....you know that I love your Q parts shop.
I'll have to look at it again. I seem to recall that the brackets are spot welded onto the frame and that the cover bolts to those brackets. I'm pretty sure that my brackets are shot, so a newer cover won't really help.I'll get up under it again soon (rain today) and see what's going on.
What kind of shape is your shifter console cover like? I'm referring to the decorative plastic around the shift lever. Mine is fairly scratched up.
Beyond that, I don't really need anything at this time. The car and I have reached a level of detente which will keep me driving it for a while. Only 140K and it's running great. My plan is to take it to about 250K and then start looking for a 3rd gen Q.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Might be better to take it to 350K and hope a good 2nd gen is still rust free somewhere.
bullittandy
Brackets on my 97 parts car are bolted to frame, shoot me an email and we'll discuss.
I've got my eye on a 03 or 04 M45 at some point in my future.
Skibane
Car: 2000 Q45 AE 110K
Quote »The most obvious (and easiest to access for future changes) choice would be under the hood but those lines are probably too high psi. Correct?[/quote]Since the fuel pump is in the tank, the pressure shouldn't be any higher than it is when it comes out of the tank (and into the original fuel filter).
However, relocating the filter to the engine compartment may cause other problems - It'll get much hotter there, which will make the several ounces of fuel inside it more likely to boil...
Personally, I'd either replace the bracket with another OEM one (coating it in epoxy if I was feeling ambitious), or kludge together a replacement out of something less prone to corrosion (stainless steel maybe?)
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Skibane wrote:However, relocating the filter to the engine compartment may cause other problems - It'll get much hotter there, which will make the several ounces of fuel inside it more likely to boil...
I doubt it will be a problem, cause we G50 guys have them in the engine bay and are fine so far.
Quote »Boiling Point of Gasoline
Gasoline as used by vehicles is a mixture of roughly 230 different chemicals. Gasoline formulations vary depending upon the location, time of the year, environmental regulations, and availability. If the PEAC user looks up the boiling point of gasoline on the PEAC tool, the temperature 102o F (or 39o C) is displayed. But the information is misleading. Gasoline boils over a range of temperatures, with the most volatile components starting to boil away at roughly 102oF. The less-volatile components will boil at higher temperatures. Gasoline boils over range of temperatures, between 39 and 200o C (102oF and 392o F) typically, the temperature range varies depending upon the formulation. The final boiling point of the last residual of gasoline might be typically 225oC (437oF). This is in contrast to a pure chemical such as heptanes (one of the components of gasoline) which boils at a single temperature (209o F; 98oC).
Petroleum refining begins with the distillation of crude oil into fractions of different boiling ranges, usually called “light naphtha”, “heavy naphtha”, “kerosene”, “light gas oil”, “heavy gas oil”, and “reduced crude”. The naphtha fractions obtained by distillation are also called “virgin naphtha” or “straightrun gasoline”. The hydrocarbon products obtained by distillation depend greatly upon the type of crude oil being distilled. Kerosene and light gas oil fractions (also called middle distillates) are used in the production of kerosene, jet fuel, diesel fuel, and furnace oils. The heavy gas oil may be used for heavy diesel fuel, industrial fuel oil, and bunker fuel. All of these are mixtures of various hydrocarbon compounds with a range of boiling points. If the PEAC user looks up the boiling point for fuel oil, jet fuel, naphtha, or other petroleum distillate, a single temperature is displayed representing a temperature at the lower end of the boiling point range.
The lower boiling point hydrocarbon distillates are more valuable because they are major components of gasoline. A major petroleum refining step is hydrocracking, where higher boiling hydrocarbons are broken down or cracked forming lower boiling point hydrocarbons. The higher boiling point hydrocarbons are subjected to hydrogen and heat in the presence of a catalyst which results in the formation of lower molecular weight, lower boiling point hydrocarbons. The catalyst, which becomes fouled with carbon, is regenerated.
A typical breakdown of modern gasoline (excluding additives and oxygenated compounds) might be 15% n-paraffins (examples: pentane, hexane, heptane, octane, decane, etc.); 30% iso-paraffins (examples: 1-methylpropane, 2-methylbutane, 2,2,3-trimethylbutane, etc.); 12% cycloparaffins (example: cyclohexane, cyclopentane, etc.); 35% aromatics (examples: benzene, toluene, ethyl benzene, 1,3,5-trimethylbenzene; m-xylene, etc.); and 8% olefins (examples: 2-pentene, 2-methylbutene, cyclopentene, etc.). The octane number of the gasoline is a function of the components.
The U.S. Environmental Protection Agency has specified that gasoline contain a minimum of 2% oxygen by weight to reduce automotive emissions and improve air quality in polluted areas. This can be done by adding alcohols, notably ethanol, to gasoline to supply the oxygen component. Until recently, refiners have added methyl tert-butyl ether (MTBE) to gasoline to supply the oxygen component; a gasoline composition of 12% MTBE would meet the 2% oxygen by weight requirement. But MTBE proved to be a dangerous pollutant itself, contaminating groundwater from leaking gasoline tanks at fuel stations.
Modern refiners add detergents (usually an amide compound and alkylammonium dialkyl phosphate to prevent the formation of contaminants in the carburetor or fuel injectors. Light lubricants may be added to help lubricate cylinders and top piston rings. Deicing and anticorrosion additives are also in modern gasolines. Organic dyes are also added to identify brands and grades of gasoline.
In summary, gasoline is a mixture of many different chemicals. Many of the components of modern gasoline are also individually listed in the PEAC tool. The mixture boils over a temperature range rather than at a single temperature. [/quote]Source: http://www.aristatek.com/Newsl...g.htm
Q451990
I would be very careful about relocating the fuel filter... we had someone put a plastic fuel filter in a different location in a G50 a few years ago post about an engine bay fire. So if you go that route...be sure you know what you're doing!
Heath
