Secondary ignition coil
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Mopowa
Car: 1986 720 pickup
On my '86(85 1/2) Z24, my ignition coil that fires the intake plugs quit firing. Instead of spending time and money troubleshooting why it quit, I just swapped the coil wires so that the exhaust plug coil would fire the intake side plugs and set the timing accordingly. My question is: will this cause any ill effects down the road? Thanks!
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Don't see why you would need two sets of spark. You should be fine.
PEZi
yeah... you don't need the exhaust coil... just replace it if it bothers you at all when you have time but really...not a big deal
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
The second coil is for emissions. If you're sensitive you would feel the difference in the power, but the power loss is negligible.
Return to “Datsun 720”
