Secondary butterfly valves...remove?
RedSubdivisions
Car: 1989 BMW 325i, 2002 BMW 330i
I've removed all my emissions in my car and the only thing that I have left is the secondary butterly valves. i noticed it is vacuum operated. would removal of the emissions affect the butterfly valves? should i leave it attached to a vacuum source? or remove it completely?
Firewind
Car: 240SX
I would remove it completely, plug the hole from the rod, and no more butterfly's, less resistance in the manifold.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Doesn't that decrease your torque in the low rpms? There must be threads on this.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
yes and yes
Shabbernigdo
4cefed wrote:Doesn't that decrease your torque in the low rpms? There must be threads on this.
yes i belive the loss of torque was between 1k and 1.5k rpm'sbut even so its not a major loss / slightly noticable tho.
ive removed all my vacume lines other then the one that operates the fpr and just left the secondary butterflies open for the time being and have had no problems with it.
RedSubdivisions
This was literally the perfect response I was looking for. lol
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Does the increased top end make up for the marginal loss at such a low rpm?
Shabbernigdo
no noticable top end gains from what i can tell but in the end with them disconnected its just one less place for a vacume leak and one less mechanical part to fail and give u problems down the road.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
I was thinking of removing them for just those reasons. Thanks for reinforcing the idea.
cornuts
Car: 91 nissan 240sx
sorry to go lil off topichow do u leave them open may i ask..and i was removing all emission shiz and found this bubble like mechinizum with a vacuum connected to it and bolted to the mani is that part of the butterflies? it was next to the egr
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
I think you are describing the actuator for the butterflies.
cornuts
yeap you are correct!!!
