If it is simply a gear that you could replace you may want to take what is left or steal off of the other seat if it is the same and have a new one made or purchase one off the shelf. There are many companies that do both and you could easily permanent fix your problem.elleng35 wrote:Does anyone know if power & heated drivers seat from 2003 will be the same part to replace my 2004 broken seat. Power track crapped out. Seems to be common problem on 03 and 04.
