RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Tue May 17, 2011 6:46 am
The best way to figure it out is to unbolt the seats and then flip them over and locate the mounting points on the rails and measure them. Then go to a junk yard that allows you to remove parts yourself and find some good buckets that are same or real close to same width and depth and check to see if the rails or mounting points on the new seats are close enough in width and depth to mate to stock rails. Pathy seats fit and i found some leather ones in pretty good shape at local pull a part and they bolted right in. may take a while and some searching but there are good ones still out there.try ebay or find a pull a part close by and make a trip and search, that is what i did after about 1 yr of looking I found great gray leather that matched my interior for 25 bucks a seat.If you have buddies in other towns they can check local pull a part. Google pull a part they list all sites nationally and you can look up the path finders to see who has one.
