Seatbelt return weak on QX4
John S
Car: 2001 Infiniti QX4
Hope someone can help. My drivers side seatbelt retract is real weak. The seat belt ends up getting caught in the door. It will retract, you just have to help it along. Anyone else dealt with this or had it apart. I was checking out salvage belts at car-parts.com but if there's an easy fix I don't want to replace the whole thing.
Thanks
Pwnin O'Brien
There is a TSB for this issue. Basically the fix is to get a kit from the dealership, which is a little piece of tape, and you just apply it to the seat belt eye-ring (the part that the seat belt goes through that is vertically adjustable). This is supposed to fix the slow set belt return.
Here's a little more info on the problem... http://www.nissantechinfo.com/...year=
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
will a piece of tape really fix this? i have same issue.
John S
Alright, maybe this will actually do it.
I found the full copy of the Service Bulletin athttp://www.jatan.net/tsbs/056037.pdf
Thanks alot.
exvin
Car: 2000 Nissan Pathfinder
Wow, I have to try this cus I have the same problem and boy....does it get annoying..Especially when you are having a bad day
